はじめに
Is the LCD screen on your Coolpix S230 cracked or damaged? This guide will walk you through how to replace it.
必要な工具と部品
Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
Remove the two 3-mm screws from the other side of the camera.
Finally, remove the three 4-mm screws from the bottom of the camera.
Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
