はじめに
If the battery is dead or the memory card is full, it must be changed or charged. In order to accomplish either they must be removed. This guide will show the reader how to simply remove either one.
ツール
工具は必要ありません。
パーツ
  1. Slide the battery and memory card cover (located on the bottom of the camera) to release it.
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  4. To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
まとめ
2 の人々がこのガイドを完成させました。
Shauna
メンバー登録日: 2011年04月05日
750 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-32, Maness Spring 2011 Cal Poly, Team 12-32, Maness Spring 2011人のメンバー
CPSU-MANESS-S11S12G32
4 メンバー
5のガイドは作成済み
コメント1件
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - 返信
統計データを表示:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 47
今までの合計 17,128
