この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You will be removing the back casing of the camera. You will need a Phillips #00 screwdriver and a spudger. You will then be directed to remove screws.
必要な工具と部品
Place thumb on the battery cover panel on the bottom of the device.
Slide the panel to the right away from the camera.
After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
2 の人々がこのガイドを完成させました。
