メインコンテンツにスキップ
Nikon Coolpix S210 LCD screen Replacement
必要な工具と部品
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: 手順 1、 1の画像 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: 手順 2、 2の画像 1 Nikon Coolpix S210 LCD screen Replacement: 手順 2、 2の画像 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
    Thank You!!! Amazing how easily I can complicate anything!! You are my hero. Retro picture taking ~ here I come!!
    Jennifer Curran - 返信
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: 手順 3、 1の画像 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: 手順 4、 1の画像 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: 手順 5、 1の画像 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: 手順 6、 2の画像 1 Nikon Coolpix S210 LCD screen Replacement: 手順 6、 2の画像 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: 手順 7、 3の画像 1 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 手順 7、 3の画像 2 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 手順 7、 3の画像 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: 手順 8、 1の画像 1
    • Gently remove the LCD screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Mallory Arend
メンバー登録日: 01/17/11
444 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G17
6 メンバー
12のガイドは作成済み
コメント 1 件
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 3,978
