メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This is the first part to taking apart your Nikon Coolpix S210.
パーツ
パーツは指定されていません。
  1. Place thumb on the battery cover panel on the bottom of the device.
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Slide the orange latch outward towards the corner of the camera. The battery should pop out.
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Unscrew the two 4.05mm screws on the side next to the buttons.
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Gently wedge the flat end of the spudger between the back case and the wrist-strap mount. The wrist-strap mount is the thin metal piece on the side of the camera.  Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
終わりに
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different sizes of screws.
ある他の人がこのガイドを完成しました。
Paul Doyle
メンバー登録日: 2011年01月20日
480 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G17
6 メンバー
12のガイドは作成済み
コメント1件
What about the front case so I can replace the flash board on top?
danwat1234 - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,069
