はじめに
Note that the LCD screen display and the glass screen are separate parts.
必要な工具と部品
Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
Push the door open, and remove the existing battery with your fingers, per images 2-3.
Remove both 4.5 mm screws holding the bottom into place.
Remove both 4.5 mm screws holding the side into place.
Remove the 4.5 mm screw underneath the A/V flap.
Remove the 4.0 mm screw on the left-side wrist strap loop.
2 の人々がこのガイドを完成させました。
4 件のコメント
Hello Elizabeth,
I have just followed the video’s for replacing a screen on my Coolpix P90.
The procedure was excellent and for an old Australian (born 1931) I never had a problem.
Just one question, is there a special way for reconnecting the data transfer ribbon.
Just cannot reconnect.
Thank you.
Regards, Noman
QLD Australia.
Help! I must be missing something. I only need to replace the screen and I can’t get the angled screen to lay flat. Because of this I cant access the two screws on the back “extension” piece allowing me to remove the plastic cover on the back of the screen. The camera is a coolpix P90. Any advice?
I also need to know where to buy a new screen.
Everywhere I look on line there are only parts listed for newer models.
Thanks, Allen
