メインコンテンツにスキップ
Nikon Coolpix P90 Eyepiece Replacement
必要な工具と部品
  1. Nikon Coolpix P90 Eyepiece Replacement, Camera Base: 手順 1、 3の画像 1 Nikon Coolpix P90 Eyepiece Replacement, Camera Base: 手順 1、 3の画像 2 Nikon Coolpix P90 Eyepiece Replacement, Camera Base: 手順 1、 3の画像 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: 手順 2、 3の画像 1 Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: 手順 2、 3の画像 2 Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: 手順 2、 3の画像 3
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • On the bottom side of the camera, unscrew both 4.5 mm screws holding the bottom into place, per image 1.
    • On the right side of the camera, unscrew both 4.5 mm screws holding the side into place, per image 2.
    • On the right side of the camera, unscrew the 4.5 mm screw underneath the A/V flap, per image 2.
    • On the top side of the camera, unscrew the 4.0 mm screw on the left-side wrist strap loop, per image 3.
  3. Nikon Coolpix P90 Eyepiece Replacement: 手順 3、 2の画像 1 Nikon Coolpix P90 Eyepiece Replacement: 手順 3、 2の画像 2
    • Use a Phillips #000 Precision Screwdriver for the following step.
    • Lift up the LCD screen to reveal the two screws.
    • Unscrew the two 3.0 mm screws that hold the arm in place, per image 2.
  4. Nikon Coolpix P90 Eyepiece Replacement: 手順 4、 1の画像 1
    • Carefully lift up the back cover from the rear side of the camera.
    • Possible Device Damage: Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard, per image 1.
  5. Nikon Coolpix P90 Eyepiece Replacement: 手順 5、 2の画像 1 Nikon Coolpix P90 Eyepiece Replacement: 手順 5、 2の画像 2
    • Press your finger on the top of the ribbon latch and pull it down and toward you to open the safety latch and free the ribbon, per image 1.
    • Possible Device Damage: Be careful when releasing the safety latch because it is fragile and may break easily.
    • Slide the ribbon out from its socket.
    • It is now safe to completely remove the back cover from the camera.
  6. Nikon Coolpix P90 Eyepiece Replacement: 手順 6、 2の画像 1 Nikon Coolpix P90 Eyepiece Replacement: 手順 6、 2の画像 2
    • On the back side of the camera, unscrew the seven 4.0 mm screws that connect the metal plate to the motherboard, per image 1.
    • On the top side or the camera, unscrew the three 4.0 mm screws that connect the metal hinges to the camera body, per image 2.
  7. Nikon Coolpix P90 Eyepiece Replacement: 手順 7、 1の画像 1
    • Carefully lift the metal backing from the motherboard.
    • Possible Device Damage: Do NOT completely remove the metal backing yet. There is a data transfer ribbon connecting the metal backing to the motherboard, per image 1.
  8. Nikon Coolpix P90 Eyepiece Replacement: 手順 8、 2の画像 1 Nikon Coolpix P90 Eyepiece Replacement: 手順 8、 2の画像 2
    • Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon, per image 1.
    • It is now safe to completely remove the metal backing from the camera.
  9. Nikon Coolpix P90 Eyepiece Replacement: 手順 9、 1の画像 1
    • Unscrew the 3.0 mm screw that holds the eyepiece in place, per image 1.
  10. Nikon Coolpix P90 Eyepiece Replacement: 手順 10、 1の画像 1
    • Possible Device Damage: Do NOT completely remove the eyepiece yet. There is a data transfer ribbon connecting the eyepiece to the motherboard, per image 1.
    • Using a plastic opening tool, carefully unlatch the safety latch that holds the eyepiece data transfer ribbon in place.
  11. Nikon Coolpix P90 Eyepiece Replacement: 手順 11、 1の画像 1
    • Remove the eyepiece from the camera by gently pulling it back.
    • Replace the old eyepiece with a new eyepiece.
    • Congratulations, the repair is finished!
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Elizabeth Kamine
メンバー登録日: 01/22/15
655 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-14, Maness Winter 2015 Cal Poly, Team 20-14, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S20G14
4 メンバー
7のガイドは作成済み
コメント 1 件
Excellent Illustrative photographs and instructions
Charles Ikerman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 806
