はじめに
Follow this guide to replace the battery of your Nikon Coolpix P90 camera with a fully charged EN-EL5 rechargeable Li-ion battery. It provides 3.7V and 1100mAh. Check your battery to ensure you are replacing with a compatible model.
Make sure that your camera is off and unplugged from the charger before you begin this repair.
Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
Push the door open, and remove the existing battery with your fingers, per images 2-3.
