メインコンテンツにスキップ
Nikon Coolpix P510 Battery Removal Replacement
必要な工具と部品
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: 手順 1、 1の画像 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: 手順 2、 2の画像 1 Nikon Coolpix P510 Battery Removal Replacement: 手順 2、 2の画像 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
終わりに
作成者
2人の作成者と共同で作成されました。
Brian Hulsey
メンバー登録日: 03/31/15
1,461 ポイント
6のガイドは作成済み
チーム
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S2G2
3 メンバー
12のガイドは作成済み
3 件のコメント
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - 返信
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - 返信
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 31
今までの合計 4,128
