1. Turn the front of the camera toward you.
    • Turn the front of the camera toward you.
  2. On the left side of the camera, using a Phillips #00 Precision Screwdriver, remove the two screws. On the left side of the camera, using a Phillips #00 Precision Screwdriver, remove the two screws. On the left side of the camera, using a Phillips #00 Precision Screwdriver, remove the two screws.
    • On the left side of the camera, using a Phillips #00 Precision Screwdriver, remove the two screws.
  3. On the right side of the camera, remove the first visible screw.
    • On the right side of the camera, remove the first visible screw.
  4. Lift the HDMI and A/V OUT cover to access the hidden screw.
    • Lift the HDMI and A/V OUT cover to access the hidden screw.
  5. Flipping the camera upside down, remove the seven marked screws.
    • Flipping the camera upside down, remove the seven marked screws.
  6. Remove the two screws hidden underneath the display panel. Remove the two screws hidden underneath the display panel.
    • Remove the two screws hidden underneath the display panel.
  7. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  8. Using a plastic opening tool, gently loosen up the sides of the camera. Using a plastic opening tool, gently loosen up the sides of the camera. Using a plastic opening tool, gently loosen up the sides of the camera.
    • Using a plastic opening tool, gently loosen up the sides of the camera.
  9. Carefully open the camera. There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
    • Carefully open the camera.
    • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
  10. This is the cover that houses the back buttons of the camera. Turn it around. This is the cover that houses the back buttons of the camera. Turn it around.
    • This is the cover that houses the back buttons of the camera. Turn it around.
  11. Remove the six indicated screws.
    • Remove the six indicated screws.
  12. Using a plastic opening tool, lift the metal plate and set aside. Using a plastic opening tool, lift the metal plate and set aside.
    • Using a plastic opening tool, lift the metal plate and set aside.
  13. Turn the cover around and push against the buttons. Turn the cover around and push against the buttons. Turn the cover around and push against the buttons.
    • Turn the cover around and push against the buttons.
  14. Now you have partial access to one set of the buttons.
    • Now you have partial access to one set of the buttons.
  15. On the bottom left, there are the last set of removal buttons.
    • On the bottom left, there are the last set of removal buttons.
  16. Remove the screw.
    • Remove the screw.
  17. Use a plastic opening tool to remove the button.
    • Use a plastic opening tool to remove the button.
  18. Now you have removed the back button of the camera.
    • Now you have removed the back button of the camera.
まとめ
Nghiem Ngo
メンバー登録日: 2015年01月15日
264 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015人のメンバー
USFT-TANSKI-W15S1G1
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 419
