メインコンテンツにスキップ
Nikon Coolpix L840 Motherboard Replacement
必要な工具と部品
  1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Nikon Coolpix L840 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Nikon Coolpix L840 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Motherboard Replacement: 手順 2、 1の画像 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Motherboard Replacement: 手順 3、 2の画像 1 Nikon Coolpix L840 Motherboard Replacement: 手順 3、 2の画像 2
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Abraham Lozano
メンバー登録日: 04/11/16
595 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S1G11
4 メンバー
10のガイドは作成済み
2 件のコメント
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
waynelguyton - 返信
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
Stephen Scanlan - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 1,965
