はじめに
The shutter is a very important part of the camera because without it you can't take pictures. This guide will give you the steps to access this button and replace this button.
必要な工具と部品
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
Remove these five Phillips screws, from the back of the camera, with the Phillips screwdriver.
2 の人々がこのガイドを完成させました。
3 件のコメント
Muy bueno pero falta documentar 3 tornillos.
1. En el paso 1, en la tercera foto debajo del sticker del código de barras.
2. En el paso 2, justo en el fondo del compartimento de una de las baterías (la del extremo). Incluso se alcanza a apreciar en la foto.
3. En el paso 8, en esa misma pieza de metal a un lado está el otro tornillo.
cyrez_1509 - 返信
My shutter button still works but doesn’t give feedback. It’s hard to tell when I’ve taken a picture because it doesn’t “click.” I’m wondering if that’s something that can be fixed, but I can’t tell if the mechanism for that feedback is in the mechanical portion above (and maybe a piece of metal broke) or built into the switch soldered on the circuit board.
Dove si può acquistare il bottone a buon prezzo? grazie
Where can you buy the button at a good price? Thank you
