はじめに
This guide will walk you through the steps and tools required to properly replace the camera's shutter button.
必要な工具と部品
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
終わりに
ある他の人がこのガイドを完成しました。
