はじめに
If your camera is not turning on or reacting to anything you do, follow this guide on how to change the batteries.
必要な工具と部品
Orientate the camera so that the lens is pointing left. The battery door is located on the bottom of the camera.
To unlock the battery door slide the switch on the battery door to the right.
Slide the battery door towards you and lift to open.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
