メインコンテンツにスキップ
Nikon Coolpix L610 Camera Lens Replacement
必要な工具と部品
  1. Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: 手順 1、 2の画像 1 Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: 手順 1、 2の画像 2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Camera Lens Replacement: 手順 2、 1の画像 1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Camera Lens Replacement: 手順 3、 1の画像 1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Camera Lens Replacement: 手順 4、 3の画像 1 Nikon Coolpix L610 Camera Lens Replacement: 手順 4、 3の画像 2 Nikon Coolpix L610 Camera Lens Replacement: 手順 4、 3の画像 3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 手順 5、 3の画像 1 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 手順 5、 3の画像 2 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 手順 5、 3の画像 3
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Camera Lens Replacement: 手順 6、 1の画像 1
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
  7. Nikon Coolpix L610 Camera Lens Replacement, Removing the screen: 手順 7、 1の画像 1
    • Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
  8. Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: 手順 8、 2の画像 1 Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: 手順 8、 2の画像 2
    • While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
  9. Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 手順 9、 3の画像 1 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 手順 9、 3の画像 2 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 手順 9、 3の画像 3
    • Remove the 6 (3.70 mm) screws on the metal cover. Two of those screws are covered by black plastic covers.
    • After removing the screws the panel should come off and will look like the final image.
    • Be careful of the red and black wires on the top. If the flash is charged you could get a mild shock.
  10. Nikon Coolpix L610 Camera Lens Replacement: 手順 10、 1の画像 1
    • Unplug the two ribbons for the lens. There will be latch that will need to be slid down. After loosening the latch, the ribbon should be able to be easily pulled out.
  11. Nikon Coolpix L610 Camera Lens Replacement: 手順 11、 2の画像 1 Nikon Coolpix L610 Camera Lens Replacement: 手順 11、 2の画像 2
    • Remove the 3 (3.10 mm) screws that are located on the back of the lens cover.
    The top and bottom red circles are obviously misplaced, those two screws are the other black ones below and to the left and right of the middle one.
    xonoxf - 返信
  12. Nikon Coolpix L610 Camera Lens Replacement: 手順 12、 3の画像 1 Nikon Coolpix L610 Camera Lens Replacement: 手順 12、 3の画像 2 Nikon Coolpix L610 Camera Lens Replacement: 手順 12、 3の画像 3
    • There are two lens covers that will fall out after removing the back lens plate.
    • Remove the 6 (4.35 mm) screws surrounding the lens.
    • There are 2 more (3.70 mm) screws covered by a small black square located. Remove the black squares and proceed to unscrewing these final screws.
    • Remove the lens. It should just be free to pull it out.
    It is not necessary to remove the six screws circled in red. To remove the lens unit, you just have to remove the two covered screws circled yellow.
    xonoxf - 返信
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jeremy
メンバー登録日: 01/21/15
1,027 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015人のメンバー
USFT-BROWN-W15S9G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 2,332
