メインコンテンツにスキップ
Nikon Coolpix L340 LCD Screen Replacement
必要な工具と部品
  1. Nikon Coolpix L340 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 1 Nikon Coolpix L340 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 2 Nikon Coolpix L340 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 3
    • Remove two 5 mm Philips #000 screws on the left hand side of the camera located on the side where the batteries are inserted.
    • Remove two 5 mm Philips #000 screws on the bottom of the camera.
    • Remove two 5 mm Philips #000 screws on the left hand side of the camera located near the power button.
  2. Nikon Coolpix L340 LCD Screen Replacement: 手順 2、 3の画像 1 Nikon Coolpix L340 LCD Screen Replacement: 手順 2、 3の画像 2 Nikon Coolpix L340 LCD Screen Replacement: 手順 2、 3の画像 3
    • After removing all six screws, you should be able to remove the plastic cover that holds the buttons and keeps the LCD screen in place.
    • Once you remove the back cover you should be able to access the bracket piece that holds the LCD screen.
    • Notice that the LCD screen is connected to the motherboard via a very fragile circuit piece, be very care removing the old and attaching the new LCD screen so that nothing else gets broken.
  3. Nikon Coolpix L340 LCD Screen Replacement: 手順 3、 2の画像 1 Nikon Coolpix L340 LCD Screen Replacement: 手順 3、 2の画像 2
    • In order to get to the motherboard to disconnect the old LCD screen, you need to remove three 5 mm Phillips #000 screws that connect the bracket piece to the motherboard.
  4. Nikon Coolpix L340 LCD Screen Replacement: 手順 4、 2の画像 1 Nikon Coolpix L340 LCD Screen Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • To remove the old LCD screen from the motherboard, there is an off-white ribbon on the motherboard that, the thin black ZIF (Zero Insertion Force) connector that needs to be lifted up so that the circuit piece connected to the LCD screen can be pulled out.
    • Using tweezers or fingers gently disconnect the LCD screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Joseph Harrington
メンバー登録日: 03/04/16
143 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S3G3
4 メンバー
8のガイドは作成済み
2 件のコメント
Is there a plastic cover as part of the rear cover on the L340? Trying to determine what exactly is cracked
megblackwell - 返信
Very helpful. Thanks
Haibin Zheng - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 2,426
