メインコンテンツにスキップ
Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: 手順 1、 2の画像 1 Nikon Coolpix L340 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: 手順 2、 2の画像 1 Nikon Coolpix L340 Battery Replacement: 手順 2、 2の画像 2
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: 手順 3、 1の画像 1
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: 手順 4、 1の画像 1
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nikki Butts
メンバー登録日: 03/04/16
179 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S3G3
4 メンバー
8のガイドは作成済み
4 件のコメント
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - 返信
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - 返信
thestevelink - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 133
今までの合計 9,743
