メインコンテンツにスキップ
Nikon Coolpix L26 Camera Front Cover Replacement
必要な工具と部品
  1. Nikon Coolpix L26 Camera Front Cover Replacement, Back Cover: 手順 1、 3の画像 1 Nikon Coolpix L26 Camera Front Cover Replacement, Back Cover: 手順 1、 3の画像 2 Nikon Coolpix L26 Camera Front Cover Replacement, Back Cover: 手順 1、 3の画像 3
    • Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
  2. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 2、 1の画像 1
    • Using the Phillips #000 screwdriver, unscrew the two 2mm screws next to the battery compartment on the right side of the camera.
  3. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 3、 1の画像 1
    • Unscrew the two 2mm screws on the opposite side.
  4. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 4、 1の画像 1
    • Flip over the rubber AV cover at the bottom of the camera. Unscrew the last two 2mm screws on the bottom of the camera.
  5. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 5、 3の画像 1 Nikon Coolpix L26 Camera Front Cover Replacement: 手順 5、 3の画像 2 Nikon Coolpix L26 Camera Front Cover Replacement: 手順 5、 3の画像 3
    • Using your hands, open the camera slightly by using the indentation above the camera compartment.
  6. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 6、 2の画像 1 Nikon Coolpix L26 Camera Front Cover Replacement: 手順 6、 2の画像 2
    • Wedge the flat end of the spudger in between the front and back cover. Carefully push the spudger downward, which will lift the back cover off the camera.
  7. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 7、 1の画像 1
    • Gently pull the cover off the camera.
  8. Nikon Coolpix L26 Camera Front Cover Replacement, LCD Screen: 手順 8、 3の画像 1 Nikon Coolpix L26 Camera Front Cover Replacement, LCD Screen: 手順 8、 3の画像 2 Nikon Coolpix L26 Camera Front Cover Replacement, LCD Screen: 手順 8、 3の画像 3
    • Carefully flip over the LCD screen onto its front. Pull the top of the LCD screen toward you keeping the bottom of it inside the camera.
    • Do not pull on the LCD screen; there is a ribbon of circuitry that is connected to the motherboard.
  9. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 9、 1の画像 1
    • Gently hold the LCD screen down, so the ribbon lays flat against the back of the camera.
  10. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 10、 1の画像 1
    • Gently wedge the spudger underneath the white latch and lift the latch open.
  11. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 11、 2の画像 1 Nikon Coolpix L26 Camera Front Cover Replacement: 手順 11、 2の画像 2
    • Use the flat side of the spudger to flip the white switch on the motherboard. You should hear a light click.
  12. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 12、 1の画像 1
    • Gently pull the ribbon out of the switch.
  13. Nikon Coolpix L26 Camera Front Cover Replacement, Front Cover: 手順 13、 2の画像 1 Nikon Coolpix L26 Camera Front Cover Replacement, Front Cover: 手順 13、 2の画像 2
    • Open the battery compartment door by sliding the white switch upwards. Push the door towards the right of the camera.
  14. Nikon Coolpix L26 Camera Front Cover Replacement: 手順 14、 3の画像 1 Nikon Coolpix L26 Camera Front Cover Replacement: 手順 14、 3の画像 2 Nikon Coolpix L26 Camera Front Cover Replacement: 手順 14、 3の画像 3
    • Hold the camera with the lens face down to prevent the plastic covers of the warning light and the flash bulb from falling out.
    • Take a firm hold of the black inner casing of the top and bottom of internal camera. With your other hand, take a hold of the red front case.
    • With slight force, pull the internal camera upwards and out of the front case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Sadie
メンバー登録日: 02/16/15
427 ポイント
3のガイドは作成済み
チーム
San Diego State, Team 1-3, Sheppard Winter 2015 San Diego State, Team 1-3, Sheppard Winter 2015人のメンバー
SDSU-SHEPPARD-W15S1G3
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 43
今までの合計 2,270
