メインコンテンツにスキップ
はじめに
This guide will walk you through the necessary steps to access and remove the LCD screen in the Nikon Coolpix E5700.
パーツ
パーツは指定されていません。
  1. Use your finger tip to slide the battery release tab toward the battery symbol on the E5700. Open the battery door.
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Pull the battery out of the E5700.
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Remove two Phillips screws (3.4 mm) located on the left side of the screen.
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
  4. Remove two Phillips screws (3.4 mm) located on the right side of the screens. Remove two Phillips screws (3.4 mm) located on the right side of the screens.
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
  5. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  6. Remove back plastic monitor cover. Remove back plastic monitor cover.
    • Remove back plastic monitor cover.
  7. Remove the Phillips screw on the top right side of the screen.
    • Remove the Phillips screw on the top right side of the screen.
  8. Carefully unplug the grey bundle of wires in the white housing.
    • Carefully unplug the grey bundle of wires in the white housing.
  9. Carefully unplug the small pink and wires in the grey housing.
    • Carefully unplug the small pink and wires in the grey housing.
  10. Remove the two Phillips screws on the left side of the screen.
    • Remove the two Phillips screws on the left side of the screen.
  11. Remove the metal bar on the left side of the screen.
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
まとめ
ある他の人がこのガイドを完成しました。
Kyle Sitton
メンバー登録日: 2011年04月17日
333 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011人のメンバー
CPSU-AMIDO-S11S24G58
4 メンバー
9のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 2,203
