はじめに
This guide will walk you through the necessary steps to remove the back panel of the Nikon Coolpix E5700.
パーツ
パーツは必要ありません。
  1. Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Pull the battery out of the E5700.
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
    • Gently begin to remove the back panel.
      • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
    • Now gently unplug the two wires at the bottom of the panel.
まとめ
2 の人々がこのガイドを完成させました。
Raana
メンバー登録日: 2011年04月12日
78 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011人のメンバー
CPSU-AMIDO-S11S24G58
4 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,696
