メインコンテンツにスキップ
Nikon Coolpix B700 Motherboard Replacement
必要な工具と部品
  1. Nikon Coolpix B700 Motherboard Replacement, Back Frame Assembly: 手順 1、 1の画像 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Motherboard Replacement: 手順 2、 1の画像 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Motherboard Replacement: 手順 3、 2の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 3、 2の画像 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Motherboard Replacement: 手順 4、 1の画像 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Motherboard Replacement: 手順 5、 3の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 5、 3の画像 2 Nikon Coolpix B700 Motherboard Replacement: 手順 5、 3の画像 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Motherboard Replacement: 手順 6、 1の画像 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Motherboard Replacement: 手順 7、 2の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 7、 2の画像 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Motherboard Replacement, Internal Bracket: 手順 8、 1の画像 1
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
  9. Nikon Coolpix B700 Motherboard Replacement: 手順 9、 1の画像 1
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Motherboard Replacement: 手順 10、 1の画像 1
    • Move the ribbon out of the way to reveal the hidden screw.
  11. Nikon Coolpix B700 Motherboard Replacement: 手順 11、 1の画像 1
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Motherboard Replacement: 手順 12、 1の画像 1
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Motherboard Replacement: 手順 13、 2の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 13、 2の画像 2
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Motherboard Replacement: 手順 14、 2の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 14、 2の画像 2
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Motherboard Replacement: 手順 15、 2の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 15、 2の画像 2
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Motherboard Replacement, Motherboard: 手順 16、 1の画像 1
    • Use the metal spudger to open the latch to remove the ribbon.
  17. Nikon Coolpix B700 Motherboard Replacement: 手順 17、 1の画像 1
    • Use the Phillips screwdriver to remove the single 6 mm screw.
  18. Nikon Coolpix B700 Motherboard Replacement: 手順 18、 2の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 18、 2の画像 2
    • Gently lift the button assembly. Slide the motherboard out from the shell.
  19. Nikon Coolpix B700 Motherboard Replacement: 手順 19、 2の画像 1 Nikon Coolpix B700 Motherboard Replacement: 手順 19、 2の画像 2
    • Desolder the black, gray, and white wires from the motherboard.
    • The motherboard is labeled with the wire colors.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Carlos Salgado
メンバー登録日: 02/27/19
1,429 ポイント
7のガイドは作成済み
チーム
Purdue University Northwest, Team S4-G5, Hingst Spring 2019 Purdue University Northwest, Team S4-G5, Hingst Spring 2019人のメンバー
PNW-HINGST-S19S4G5
4 メンバー
14のガイドは作成済み
コメント 1 件
Nikon b700 all sorts part demegs
Rathod Umesh - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 672
