メインコンテンツにスキップ
Nikon Coolpix AW130 Shutter Button Replacement
必要な工具と部品
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: 手順 1、 2の画像 1 Nikon Coolpix AW130 Shutter Button Replacement, Battery: 手順 1、 2の画像 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: 手順 2、 2の画像 1 Nikon Coolpix AW130 Shutter Button Replacement: 手順 2、 2の画像 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: 手順 3、 1の画像 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: 手順 4、 2の画像 1 Nikon Coolpix AW130 Shutter Button Replacement: 手順 4、 2の画像 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: 手順 5、 2の画像 1 Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: 手順 5、 2の画像 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: 手順 6、 2の画像 1 Nikon Coolpix AW130 Shutter Button Replacement: 手順 6、 2の画像 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: 手順 7、 2の画像 1 Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: 手順 7、 2の画像 2
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: 手順 8、 3の画像 1 Nikon Coolpix AW130 Shutter Button Replacement: 手順 8、 3の画像 2 Nikon Coolpix AW130 Shutter Button Replacement: 手順 8、 3の画像 3
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Lauren Stepp
メンバー登録日: 01/29/16
1,251 ポイント
8のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Spring 2016 Western Carolina University, Team 1-4, Virtue Spring 2016人のメンバー
WCU-VIRTUE-S16S1G4
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 1,078
