メインコンテンツにスキップ
Nikon Coolpix AW130 Motherboard Replacement
必要な工具と部品
  1. Nikon Coolpix AW130 Motherboard Replacement, Battery: 手順 1、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Motherboard Replacement: 手順 2、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement: 手順 2、 2の画像 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Motherboard Replacement: 手順 3、 1の画像 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Motherboard Replacement: 手順 4、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement: 手順 4、 2の画像 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Motherboard Replacement, Front Panel: 手順 5、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement, Front Panel: 手順 5、 2の画像 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Motherboard Replacement: 手順 6、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement: 手順 6、 2の画像 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Motherboard Replacement, Back Panel: 手順 7、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement, Back Panel: 手順 7、 2の画像 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  8. Nikon Coolpix AW130 Motherboard Replacement: 手順 8、 1の画像 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  9. Nikon Coolpix AW130 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  10. Nikon Coolpix AW130 Motherboard Replacement: 手順 10、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement: 手順 10、 2の画像 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  11. Nikon Coolpix AW130 Motherboard Replacement: 手順 11、 1の画像 1
    • Carefully remove the back cover from the camera body.
  12. Nikon Coolpix AW130 Motherboard Replacement, Motherboard: 手順 12、 2の画像 1 Nikon Coolpix AW130 Motherboard Replacement, Motherboard: 手順 12、 2の画像 2
    • Using a Phillips #000 screwdriver, remove all 8, 4mm screws on the motherboard.
  13. Nikon Coolpix AW130 Motherboard Replacement: 手順 13、 1の画像 1
    • Using the nylon spudger tool, peel back the metallic plate.
    • A metal spudger is shown in the photo, but a nylon spudger should be used.
    • Do not rip the gold-colored ribbons.
  14. Nikon Coolpix AW130 Motherboard Replacement: 手順 14、 1の画像 1
    • Using your fingers, carefully disconnect the connector ribbons.
    • Though various guides suggest using a plastic or metal spudger tool to disconnect the ribbons, this tool is liable to damage the connectors.
  15. Nikon Coolpix AW130 Motherboard Replacement: 手順 15、 1の画像 1
    • Carefully remove the black piece on the lefthand side.
  16. Nikon Coolpix AW130 Motherboard Replacement: 手順 16、 1の画像 1
    • On the remaining piece, desolder the labeled soldering points.
    • The soldering tool can get extremely hot. For soldering help, check out iFixit's guide for How to Solder and Desolder Connections.
  17. Nikon Coolpix AW130 Motherboard Replacement: 手順 17、 1の画像 1
    • Flip the remaining piece over, careful not to rip any of the connecting wires.
  18. Nikon Coolpix AW130 Motherboard Replacement: 手順 18、 1の画像 1
    • Desolder at the prescribed sites.
    • Remove the motherboard from the camera body.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Lauren Stepp
メンバー登録日: 01/29/16
1,251 ポイント
8のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Spring 2016 Western Carolina University, Team 1-4, Virtue Spring 2016人のメンバー
WCU-VIRTUE-S16S1G4
5 メンバー
16のガイドは作成済み
コメント 1 件
Thanks for this guide.
I managed to open 2 of theses and swap the sensor-unit from one to another.
Unluckily the camera remains broken since one only shows a black picture - even though the sensor is alright an the other has a broken AF from a fall, I suppose...
I am certain with some silicone grease on the orange rubber the camera would still be waterproof.
Daniel Bardua - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 28
今までの合計 5,033
