はじめに
Without the LCD screen, you cannot preview your nifty vacation photos. If this screen is cracked, the waterproof qualities of the Nikon may be sacrificed. Allowing water to infiltrate into the body can cause for additional problems.
必要な工具と部品
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
Two screws are located on the right.
The remaining screws are hidden behind a connector ribbon on the left.
8 件のコメント
Hi.
Where can you buy a replacement screen?
my contact is josem6073@gmail.com
Thank you .
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - 返信
Hi.
my contact is cpapacon@gmail.com
Thank you .
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
