メインコンテンツにスキップ
Nikon Coolpix AW130 LCD Screen Replacement
必要な工具と部品
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: 手順 1、 2の画像 1 Nikon Coolpix AW130 LCD Screen Replacement, Battery: 手順 1、 2の画像 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: 手順 2、 2の画像 1 Nikon Coolpix AW130 LCD Screen Replacement: 手順 2、 2の画像 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: 手順 3、 1の画像 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 LCD Screen Replacement: 手順 4、 2の画像 1 Nikon Coolpix AW130 LCD Screen Replacement: 手順 4、 2の画像 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: 手順 5、 2の画像 1 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: 手順 5、 2の画像 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: 手順 6、 1の画像 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: 手順 7、 1の画像 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 LCD Screen Replacement: 手順 8、 2の画像 1 Nikon Coolpix AW130 LCD Screen Replacement: 手順 8、 2の画像 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 LCD Screen Replacement: 手順 9、 1の画像 1
    • Carefully remove the back cover from the camera body.
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: 手順 10、 3の画像 1 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: 手順 10、 3の画像 2 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: 手順 10、 3の画像 3
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: 手順 11、 2の画像 1 Nikon Coolpix AW130 LCD Screen Replacement: 手順 11、 2の画像 2
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: 手順 12、 1の画像 1
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
終わりに
作成者
1人の作成者と共同作成されました。
Lauren Stepp
メンバー登録日: 01/29/16
1,251 ポイント
8のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Spring 2016 Western Carolina University, Team 1-4, Virtue Spring 2016人のメンバー
WCU-VIRTUE-S16S1G4
5 メンバー
16のガイドは作成済み
8 件のコメント
Hi.
Where can you buy a replacement screen?
Ben - 返信
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - 返信
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - 返信
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - 返信
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 11
今までの合計 2,965
