はじめに
This guide will show you how to remove the monitor assembly on the Nikon Coolpix A900.
If the monitor on your camera suffers a hard drop, water damage, or gets to scratched up, you may want to replace your monitor.
This guide is relatively simple, but be sure to have a container for small parts ready.
必要な工具と部品
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
4 件のコメント
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
This is excellent but where would you get a new 3” monitor?
Have you tried AliExpress or Ebay?
photower -
