メインコンテンツにスキップ
Nikon Coolpix 995 LCD Replacement
必要な工具と部品
  1. Nikon Coolpix 995 LCD Replacement, LCD: 手順 1、 2の画像 1 Nikon Coolpix 995 LCD Replacement, LCD: 手順 1、 2の画像 2
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Nikon Coolpix 995 LCD Replacement: 手順 2、 1の画像 1
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Nikon Coolpix 995 LCD Replacement: 手順 3、 1の画像 1
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  4. Nikon Coolpix 995 LCD Replacement: 手順 4、 2の画像 1 Nikon Coolpix 995 LCD Replacement: 手順 4、 2の画像 2
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  5. Nikon Coolpix 995 LCD Replacement: 手順 5、 1の画像 1
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  6. Nikon Coolpix 995 LCD Replacement: 手順 6、 1の画像 1
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
終わりに
作成者
13人の作成者と共同で作成されました。
Cory Layman
メンバー登録日: 10/04/11
89 ポイント
3のガイドは作成済み
チーム
UW Stout, Team 1-5, Zhou Fall 2011 UW Stout, Team 1-5, Zhou Fall 2011人のメンバー
UWSTOUT-ZHOU-F11S1G5
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 16
今までの合計 2,288
