メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon Coolpix 4100 LCD screen Replacement
必要な工具と部品
  1. Nikon Coolpix 4100 LCD screen Replacement, Opening the Case: 手順 1、 1の画像 1
    • Tool on left - PH000 screwdriver
    • Tool on right - iPod fix-it tool
    • Soldering Iron
    FixBotに聞いてみる
  2. Nikon Coolpix 4100 LCD screen Replacement: 手順 2、 1の画像 1
    • Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
    FixBotに聞いてみる
  3. Nikon Coolpix 4100 LCD screen Replacement: 手順 3、 2の画像 1 Nikon Coolpix 4100 LCD screen Replacement: 手順 3、 2の画像 2
    • Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
    FixBotに聞いてみる
  4. Nikon Coolpix 4100 LCD screen Replacement: 手順 4、 1の画像 1
    • Use the iPod fix-it tool to separate the back panel from the camera.
    FixBotに聞いてみる
  5. Nikon Coolpix 4100 LCD screen Replacement, LCD screen: 手順 5、 1の画像 1
    • Use the iPod fix-it tool to carefully pry the screen from the logic board.
    • There's a ribbon cable that connects the screen to the logic board.
    FixBotに聞いてみる
  6. Nikon Coolpix 4100 LCD screen Replacement: 手順 6、 1の画像 1
    • This view shows the ribbon cable that connects to the screen.
    FixBotに聞いてみる
  7. Nikon Coolpix 4100 LCD screen Replacement: 手順 7、 1の画像 1
    • Flip the screen down. To disconnect the ribbon cable from the logic board, rock each end of the brown metal retainer that holds the ribbon cable in place until the ribbon disconnects.
    FixBotに聞いてみる
  8. Nikon Coolpix 4100 LCD screen Replacement: 手順 8、 1の画像 1
    • Remove the two screws on the top edge of the circuit board to the right of the viewfinder.
    FixBotに聞いてみる
  9. Nikon Coolpix 4100 LCD screen Replacement: 手順 9、 1の画像 1
    • To connect the new screen, solder the wires in place and connect the ribbon cable to the logic board.
    FixBotに聞いてみる
  10. Nikon Coolpix 4100 LCD screen Replacement: 手順 10、 1の画像 1
    • Unthread the four wires running across the top of the viewfinder from the plastic brackets holding them in place.
    FixBotに聞いてみる
  11. Nikon Coolpix 4100 LCD screen Replacement: 手順 11、 1の画像 1
    • Remove the two black screws threaded vertically into the top of the viewfinder. Loosen the flash and circuit board for more accessibility. This will allow for the viewfinder to be replaced.
    FixBotに聞いてみる
終わりに
作成者
12人の作成者と共同で作成されました。
Travis Buck
メンバー登録日: 09/25/12
113 ポイント
2のガイドは作成済み
チーム
Ohio State, Team 1-2, Buehl Fall 2012 Ohio State, Team 1-2, Buehl Fall 2012人のメンバー
OSU-BUEHL-F12S1G2
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 66
今までの合計 1,705
