メインコンテンツにスキップ
Nikon Coolpix 3500 Front Cover Replacement.
必要な工具と部品
  1. Nikon Coolpix 3500 Front Cover Replacement., Battery: 手順 1、 1の画像 1
    • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
    • Remove the battery.
    • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
  2. Nikon Coolpix 3500 Front Cover Replacement., Front Cover: 手順 2、 1の画像 1
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Nikon Coolpix 3500 Front Cover Replacement.: 手順 3、 1の画像 1
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Nikon Coolpix 3500 Front Cover Replacement.: 手順 4、 1の画像 1
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Nikon Coolpix 3500 Front Cover Replacement.: 手順 5、 1の画像 1
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  6. Nikon Coolpix 3500 Front Cover Replacement.: 手順 6、 2の画像 1 Nikon Coolpix 3500 Front Cover Replacement.: 手順 6、 2の画像 2
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  7. Nikon Coolpix 3500 Front Cover Replacement.: 手順 7、 2の画像 1 Nikon Coolpix 3500 Front Cover Replacement.: 手順 7、 2の画像 2
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
終わりに
作成者
5人の作成者と共同で作成されました。
richard guenther
メンバー登録日: 04/19/10
183 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S30G38
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 1,900
