メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon Coolpix 3500 Lens Replacement
必要な工具と部品
    1. Nikon Coolpix 3500 Lens Replacement, Battery: 手順 1、 1の画像 1
      • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
      • Remove the battery.
      • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
      FixBotに聞いてみる
      コメントを追加
    1. Nikon Coolpix 3500 Lens Replacement, Front Cover: 手順 2、 1の画像 1
      • Remove the two 4.5 mm screws that sit next to the battery slot.
      • Remove the 3 mm screw that sits below the CF card slot.
      • Remove the 4.5 mm screw that sits above the digital I/O cover.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon Coolpix 3500 Lens Replacement: 手順 3、 1の画像 1
      • Remove the two 4.5 mm screws that sit inside the battery slot.
      FixBotに聞いてみる
      コメントを追加
    3. Nikon Coolpix 3500 Lens Replacement: 手順 4、 1の画像 1
      • Remove the two 5 mm screws that sit near the camera strap eyelet.
      • Remove the camera strap eyelet.
      FixBotに聞いてみる
      コメントを追加
    4. Nikon Coolpix 3500 Lens Replacement: 手順 5、 1の画像 1
      • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
      FixBotに聞いてみる
      コメントを追加
    5. Nikon Coolpix 3500 Lens Replacement: 手順 6、 2の画像 1 Nikon Coolpix 3500 Lens Replacement: 手順 6、 2の画像 2
      • Remove the five 3.5 mm screws that sit at the bottom of the camera.
      • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
      • Do not apply too much force; two wires still connect the front cover to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    6. Nikon Coolpix 3500 Lens Replacement: 手順 7、 2の画像 1 Nikon Coolpix 3500 Lens Replacement: 手順 7、 2の画像 2
      • Using a spudger, detach the white-capped wire.
      • Using a spudger, detach the orange-capped wire and set the front cover aside.
      FixBotに聞いてみる
      コメントを追加
    1. Nikon Coolpix 3500 Lens Replacement, Lens: 手順 8、 1の画像 1
      • Disconnect the grey-capped wire from the motherboard.
      • Disconnect the blue wire attached to the green chip from the center of the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon Coolpix 3500 Lens Replacement: 手順 9、 2の画像 1 Nikon Coolpix 3500 Lens Replacement: 手順 9、 2の画像 2
      • Remove the 3.5 mm screw from the motherboard next to the rotating lens.
      • Invert the motherboard and lens toward the orange and blue wires still connecting the motherboard to the LED screen.
      FixBotに聞いてみる
      コメントを追加
    3. Nikon Coolpix 3500 Lens Replacement: 手順 10、 2の画像 1 Nikon Coolpix 3500 Lens Replacement: 手順 10、 2の画像 2
      • Disconnect the blue wire connecting the motherboard to the LED screen.
      • Disconnect the orange wire using a spudger while pushing out horizontally.
      • Disconnect the red capped wire from the motherboard.
      • Lift the motherboard and lens (still connected) out of the back case.
      FixBotに聞いてみる
      コメントを追加
    4. Nikon Coolpix 3500 Lens Replacement: 手順 11、 1の画像 1
      • Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
7人の作成者と共同で作成されました。
richard guenther
メンバー登録日: 04/19/10
183 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S30G38
5 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 36
今までの合計 3,516
