メインコンテンツにスキップ
Nikon CoolPix S600 LCD Replacement
必要な工具と部品
  1. Nikon CoolPix S600 LCD Replacement, Front and Rear Casing: 手順 1、 1の画像 1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 LCD Replacement: 手順 2、 1の画像 1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 LCD Replacement: 手順 3、 1の画像 1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 LCD Replacement: 手順 4、 2の画像 1 Nikon CoolPix S600 LCD Replacement: 手順 4、 2の画像 2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 LCD Replacement: 手順 5、 2の画像 1 Nikon CoolPix S600 LCD Replacement: 手順 5、 2の画像 2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 LCD Replacement: 手順 6、 1の画像 1
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 LCD Replacement: 手順 7、 1の画像 1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 LCD Replacement: 手順 8、 2の画像 1 Nikon CoolPix S600 LCD Replacement: 手順 8、 2の画像 2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 LCD Replacement: 手順 9、 1の画像 1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 LCD Replacement: 手順 10、 3の画像 1 Nikon CoolPix S600 LCD Replacement: 手順 10、 3の画像 2 Nikon CoolPix S600 LCD Replacement: 手順 10、 3の画像 3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 LCD Replacement, LCD: 手順 11、 1の画像 1
    • Gently remove LCD ribbon from the mother board
    • The screen will still be connected to the mother board by two very small wires (black & red)
  12. Nikon CoolPix S600 LCD Replacement: 手順 12、 1の画像 1
    • Desolder both wires from the mother board.
    • Refer to iFixit's solder/desoldering guide for the correct procedure to desolder the connection.
  13. Nikon CoolPix S600 LCD Replacement: 手順 13、 1の画像 1
    • Separate the LCD screen from the rest of the mother board
終わりに
作成者
3人の作成者と共同で作成されました。
andreas anggasastra
メンバー登録日: 09/14/11
116 ポイント
5のガイドは作成済み
チーム
Cuesta, Team 1-6, Zipperian Fall 2011 Cuesta, Team 1-6, Zipperian Fall 2011人のメンバー
CUESTA-ZIPPERIAN-F11S1G6
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 1,313
