メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Remove the chrome side cover from the body of the camera.
    • Remove the chrome side cover from the body of the camera.
  3. Remove the four 3.2 mm screws on the bottom of the camera.
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward) Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  6. Gently separate the back cover from the body of the camera. The back casing will still be connected to the circuit board by a ribbon
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  7. Use the tweezers to disconnect the ribbon from the circuit board.
    • Use the tweezers to disconnect the ribbon from the circuit board.
  8. Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  9. Gently separate the front cover from the body of the camera. The front casing will still be connected to the circuit board by a few wires
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  10. Remove the two 3.2 mm screws that hold the flash to the front cover.
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  11. Use the Spudger to remove the copper colored light bulb clip. Remove the front cover entierly from the camera body. Remove the front cover entierly from the camera body.
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
まとめ
andreas anggasastra
メンバー登録日: 2011年09月14日
116 ポイント
5のガイドは作成済み
チーム
Cuesta, Team 1-6, Zipperian Fall 2011 Cuesta, Team 1-6, Zipperian Fall 2011人のメンバー
CUESTA-ZIPPERIAN-F11S1G6
2 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,131
