メインコンテンツにスキップ
Nikon COOLPIX S9500 Navigation Panel Replacement
必要な工具と部品
  1. Nikon COOLPIX S9500 Navigation Panel Replacement, Removing Screws: 手順 1、 1の画像 1
    • Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
    • Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
  2. Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 2、 2の画像 1 Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 2、 2の画像 2
    • With the bottom of the camera facing you, slide the latch on the compartment to the left.
    • Swing the battery compartment door open.
    • Remove the 3.5 mm screw from the inside with a #00 Phillips screwdriver.
  3. Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 3、 1の画像 1
    • With the screen facing you, locate the two 3.5 mm screws on the left face of the camera. Remove them using a #00 Phillips screwdriver.
  4. Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 4、 1の画像 1
    • With the screen facing you, locate the three 3.5 mm screws on the right face of the camera. Remove them with a #00 Phillips screwdriver.
    • Two of the screws are located under the port tabs.
  5. Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 5、 2の画像 1 Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 5、 2の画像 2
    • Locate the crease where the case comes together.
    • Using a plastic prying tool, pry at the line to remove the camera case.
    • It may take several attempts to remove the case. Remember to pry at all the crease locations on the camera, and not just one spot.
  6. Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: 手順 6、 3の画像 1 Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: 手順 6、 3の画像 2 Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: 手順 6、 3の画像 3
    • Slide the yellow navigation panel to the right so that it can be lifted up.
    • It may take a little pressure to get the panel to separate.
    • Be careful not to damage the ribbon cable that is still attached to the camera.
  7. Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 7、 1の画像 1
    • Remove the three 4 mm screws with a #00 Phillips screwdriver.
  8. Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 8、 1の画像 1
    • Locate the magnet and copper tape on the left side of the camera.
    • Gently pull the copper tape off of the metal plate.
    • The copper tape is attached with some glue, so a little force will be needed to detach it.
  9. Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 9、 3の画像 1 Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 9、 3の画像 2 Nikon COOLPIX S9500 Navigation Panel Replacement: 手順 9、 3の画像 3
    • Lift the screen up and swing it to the right, exposing the circuit board underneath.
    • The navigation panel should still be attached to the circuit board with a ribbon cable as indicated in red.
    • Detach the ribbon cable that is connecting the LCD screen and the circuit board.
  10. Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel: 手順 10、 1の画像 1
    • Detach the ribbon cable connecting the navigation panel to the camera.
    • The navigation panel can now be removed.
終わりに
作成者
3人の作成者と共同で作成されました。
Jim Bui
メンバー登録日: 01/20/15
811 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-4, Blackwell Winter 2015 USF Tampa, Team 1-4, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S1G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 992
