はじめに
If your rear casing needs to be replaced, if it's been cracked for example, follow this guide to remove the current rear case. In this guide ZxY denotes a screw with Z-length and Y-width.
パーツ
パーツは指定されていません。
  1. On the bottom right of the camera, locate the battery flap switch.
    • On the bottom right of the camera, locate the battery flap switch.
  2. Move this switch to the right so the battery flap can flip open.
    • Move this switch to the right so the battery flap can flip open.
  3. Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Remove the three 3x3mm screws attached to the rear casing.
    • Remove the three 3x3mm screws attached to the rear casing.
  5. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  6. The panel can be identified by the wifi logo on its upper half on the camera's side.
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  7. Pry the panel off from the bottom using your fingernail.
    • Pry the panel off from the bottom using your fingernail.
  8. Remove the 3x2mm screw underneath the panel near the top of the camera.
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  9. Remove the 4x3mm on the opposite side near the selector wheel. Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  10. Pry the back panel away from the body of the camera, using the space you just opened up. Be careful not to damage the ribbon cable on the opposite end of the camera.
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  11. Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables. The center connector is detached by flipping the black latch up and away from the center of the camera.
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
まとめ
ある他の人がこのガイドを完成しました。
Kevin Backers
メンバー登録日: 2012年01月26日
301 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-5, Regan Winter 2012 Cal Poly, Team 9-5, Regan Winter 2012人のメンバー
CPSU-REGAN-W12S9G5
5 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 776
