メインコンテンツにスキップ
Nikon COOLPIX S610c Front Casing Replacement
必要な工具と部品
  1. Nikon COOLPIX S610c Front Casing Replacement, Battery: 手順 1、 1の画像 1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c Front Casing Replacement: 手順 2、 1の画像 1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c Front Casing Replacement: 手順 3、 1の画像 1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c Front Casing Replacement, Rear Casing: 手順 4、 1の画像 1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c Front Casing Replacement: 手順 5、 1の画像 1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c Front Casing Replacement: 手順 6、 1の画像 1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c Front Casing Replacement: 手順 7、 1の画像 1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c Front Casing Replacement: 手順 8、 2の画像 1 Nikon COOLPIX S610c Front Casing Replacement: 手順 8、 2の画像 2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c Front Casing Replacement: 手順 9、 2の画像 1 Nikon COOLPIX S610c Front Casing Replacement: 手順 9、 2の画像 2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c Front Casing Replacement: 手順 10、 2の画像 1 Nikon COOLPIX S610c Front Casing Replacement: 手順 10、 2の画像 2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Nikon COOLPIX S610c Front Casing Replacement, Front Casing: 手順 11、 1の画像 1
    • Remove the three 3x3mm screws that attach the front casing to the bottom.
  12. Nikon COOLPIX S610c Front Casing Replacement: 手順 12、 1の画像 1
    • Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
  13. Nikon COOLPIX S610c Front Casing Replacement: 手順 13、 2の画像 1 Nikon COOLPIX S610c Front Casing Replacement: 手順 13、 2の画像 2
    • Lift the back panel off the motherboard.
    • Be careful not to damage the ribbon cable that attaches the mother board to the rear panel.
  14. Nikon COOLPIX S610c Front Casing Replacement: 手順 14、 2の画像 1 Nikon COOLPIX S610c Front Casing Replacement: 手順 14、 2の画像 2
    • Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
    • Note that the white ribbon connector latch flips away from the ribbon cable.
  15. Nikon COOLPIX S610c Front Casing Replacement: 手順 15、 2の画像 1 Nikon COOLPIX S610c Front Casing Replacement: 手順 15、 2の画像 2
    • Remove the final 4x3mm screw at the top of the camera near the lens.
  16. Nikon COOLPIX S610c Front Casing Replacement: 手順 16、 2の画像 1 Nikon COOLPIX S610c Front Casing Replacement: 手順 16、 2の画像 2
    • Pry the front casing away from the body of the camera.
    • Be careful not to damage the wires that attach the front panel to the motherboard.
    • Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
  17. Nikon COOLPIX S610c Front Casing Replacement: 手順 17、 1の画像 1
    • Unscrew the three 3x2mm screws that attach the cables to the front casing.
終わりに
作成者
3人の作成者と共同で作成されました。
Bryan Bell
メンバー登録日: 01/26/12
28 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-5, Regan Winter 2012 Cal Poly, Team 9-5, Regan Winter 2012人のメンバー
CPSU-REGAN-W12S9G5
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 13
今までの合計 1,142
