メインコンテンツにスキップ
Nikon COOLPIX P600 Lens Replacement
必要な工具と部品
  1. Nikon COOLPIX P600 Lens Replacement, Tripod Mount: 手順 1、 1の画像 1
    • Position the back of the camera facing you and open the LCD screen to the left.
  2. Nikon COOLPIX P600 Lens Replacement: 手順 2、 2の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to unscrew the two 5.556 mm screws under the LCD screen.
  3. Nikon COOLPIX P600 Lens Replacement: 手順 3、 3の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 3、 3の画像 2 Nikon COOLPIX P600 Lens Replacement: 手順 3、 3の画像 3
    • Use a Phillips screwdriver and remove the eleven 5.556 mm screws around the outside frame of the camera.
  4. Nikon COOLPIX P600 Lens Replacement: 手順 4、 1の画像 1
    • Open the "HDMI" rubber flap.
    • Use a Phillips screwdriver and remove the 5.556 mm screw underneath the flap.
  5. Nikon COOLPIX P600 Lens Replacement: 手順 5、 1の画像 1
    • The flash button is located on the left side of the built-in flash compartment.
    • Press the flash button (as shown) to access flash.
  6. Nikon COOLPIX P600 Lens Replacement: 手順 6、 1の画像 1
    • Use a spudger to wedge underneath the flash
    • Pry (up and down) to separate.
    • It is important to choose a tool that is ESD-safe to avoid accidental damage to the device. A black nylon spudger, or plastic opening tool, should be used whenever possible.
  7. Nikon COOLPIX P600 Lens Replacement: 手順 7、 1の画像 1
    • Use your hands to gently pull the front and back of the camera apart.
    • Be careful not to damage the ribbon-wire shown in the red box.
  8. Nikon COOLPIX P600 Lens Replacement: 手順 8、 3の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 8、 3の画像 2 Nikon COOLPIX P600 Lens Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use needle-nose tweezers to gently lift the black/grey latch towards the ribbon-wire (the latch rotates upward to release and snaps down to lock).
    • Be careful not to break the latch. It cannot be replaced.
    • Use tweezers to gently remove ribbon-wires.
    • Pull the ribbon-wires towards the back-end of the camera.
  9. Nikon COOLPIX P600 Lens Replacement: 手順 9、 1の画像 1
    • Use a Phillips screwdriver and remove the single 6.350 mm screw, left of the mode-adjustment dial.
  10. Nikon COOLPIX P600 Lens Replacement: 手順 10、 2の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 10、 2の画像 2
    • Use needle-nose tweezers to remove the large ribbon-wire located under the screw.
    • Gently wiggle the ribbon out in an upward motion.
    • For easier access, you can push the black surface of the camera where the buttons and dials are located. Do not push too hard as this may break the plastic.
  11. Nikon COOLPIX P600 Lens Replacement: 手順 11、 2の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 11、 2の画像 2
    • Insert a plastic opening tool under the shutter button.
    • Gently pry (back and forth) between the rubber grip and camera casing.
  12. Nikon COOLPIX P600 Lens Replacement: 手順 12、 2の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 12、 2の画像 2
    • Place hands around the camera. Hold onto the mode dial and grip under the shutter button.
    • Gently push right thumb away and pull in left index finger to separate the camera halves.
  13. Nikon COOLPIX P600 Lens Replacement: 手順 13、 3の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 13、 3の画像 2 Nikon COOLPIX P600 Lens Replacement: 手順 13、 3の画像 3
    • Use a Phillips screwdriver to remove the nine 3.175 mm screws on the inside of the camera.
    • Use tweezers to remove the golden bracket.
  14. Nikon COOLPIX P600 Lens Replacement: 手順 14、 1の画像 1
    • Use tweezers to remove the white film under the shutter-release button.
    • This white film is a cover for the electrical components. The camera will not be affected if it rips or comes off completely.
    • Be careful: three high-discharge capacitor leads are located under this film, and can result in electric shock if touched.
  15. Nikon COOLPIX P600 Lens Replacement: 手順 15、 2の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 15、 2の画像 2
    • Use tweezers to remove the yellow ribbon-wire.
    • Gently wiggle it to the left and then out of its port.
  16. Nikon COOLPIX P600 Lens Replacement: 手順 16、 1の画像 1
    • Use hands to remove the metal cover.
    • Pull the cover up.
  17. Nikon COOLPIX P600 Lens Replacement: 手順 17、 1の画像 1
  18. Nikon COOLPIX P600 Lens Replacement: 手順 18、 2の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 18、 2の画像 2
    • The tripod connector is located at the bottom of the camera.
    • Use tweezers to remove the tripod connector.
  19. Nikon COOLPIX P600 Lens Replacement, Lens: 手順 19、 3の画像 1 Nikon COOLPIX P600 Lens Replacement, Lens: 手順 19、 3の画像 2 Nikon COOLPIX P600 Lens Replacement, Lens: 手順 19、 3の画像 3
    • Unscrew the three 3.175mm screws.
    • Use caution to not to lose the screws in the cavities of the camera.
  20. Nikon COOLPIX P600 Lens Replacement: 手順 20、 1の画像 1
    • Continue removing screws, keeping an awareness of the cavity right below the screw. It would be difficult to extract screw if lost in this cavity.
  21. Nikon COOLPIX P600 Lens Replacement: 手順 21、 3の画像 1 Nikon COOLPIX P600 Lens Replacement: 手順 21、 3の画像 2 Nikon COOLPIX P600 Lens Replacement: 手順 21、 3の画像 3
    • Remove lens by pulling up vertically.
    • Be careful not to damage any of the electrical ribbon on top of the lens.
終わりに
7 の人々がこのガイドを完成させました。
添付文書
作成者
7人の作成者と共同で作成されました。
Ashley Frazee
メンバー登録日: 09/14/15
300 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team 1-5, Bruce Fall 2015 CSU Fullerton, Team 1-5, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S1G5
3 メンバー
8のガイドは作成済み
3 件のコメント
Thank you this really helped me out
Robert Yeahright - 返信
Hi,
I have the same camera with a swollen battery inside, i was able to remove it following your instructions but a little black piece popped out out of nowhere, I wonder if you have the same instructions for removing a battery when it is stocked. Thanks
Bethy - 返信
where did you find the replacement lens for coolpix p610?
jan oliver barba - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 53
今までの合計 6,859
