メインコンテンツにスキップ
Nikon COOLPIX P2 WiFi Card Replacement
必要な工具と部品
  1. Nikon COOLPIX P2 WiFi Card Replacement, Case: 手順 1、 1の画像 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 WiFi Card Replacement: 手順 2、 1の画像 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 WiFi Card Replacement: 手順 3、 1の画像 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 WiFi Card Replacement: 手順 4、 1の画像 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 WiFi Card Replacement: 手順 5、 3の画像 1 Nikon COOLPIX P2 WiFi Card Replacement: 手順 5、 3の画像 2 Nikon COOLPIX P2 WiFi Card Replacement: 手順 5、 3の画像 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 WiFi Card Replacement: 手順 6、 1の画像 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 WiFi Card Replacement: 手順 7、 1の画像 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 WiFi Card Replacement: 手順 8、 2の画像 1 Nikon COOLPIX P2 WiFi Card Replacement: 手順 8、 2の画像 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: 手順 9、 2の画像 1 Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: 手順 9、 2の画像 2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 WiFi Card Replacement: 手順 10、 2の画像 1 Nikon COOLPIX P2 WiFi Card Replacement: 手順 10、 2の画像 2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 WiFi Card Replacement: 手順 11、 1の画像 1
  12. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: 手順 12、 1の画像 1
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 WiFi Card Replacement: 手順 13、 1の画像 1
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 WiFi Card Replacement: 手順 14、 1の画像 1
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 WiFi Card Replacement: 手順 15、 1の画像 1
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 WiFi Card Replacement: 手順 16、 1の画像 1
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 WiFi Card Replacement: 手順 17、 1の画像 1
    • Gently pull the WiFi card out of the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Joshua Avery
メンバー登録日: 01/23/12
31 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-28, Amido Winter 2012 Cal Poly, Team 3-28, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S3G28
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 891
