メインコンテンツにスキップ
Nikon COOLPIX P2 Motherboard Replacement
必要な工具と部品
  1. Nikon COOLPIX P2 Motherboard Replacement, Case: 手順 1、 1の画像 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 Motherboard Replacement: 手順 2、 1の画像 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 Motherboard Replacement: 手順 3、 1の画像 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 Motherboard Replacement: 手順 4、 1の画像 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 Motherboard Replacement: 手順 5、 3の画像 1 Nikon COOLPIX P2 Motherboard Replacement: 手順 5、 3の画像 2 Nikon COOLPIX P2 Motherboard Replacement: 手順 5、 3の画像 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 Motherboard Replacement: 手順 6、 1の画像 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 Motherboard Replacement: 手順 7、 1の画像 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 Motherboard Replacement: 手順 8、 2の画像 1 Nikon COOLPIX P2 Motherboard Replacement: 手順 8、 2の画像 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 Motherboard Replacement, LCD Screen: 手順 9、 2の画像 1 Nikon COOLPIX P2 Motherboard Replacement, LCD Screen: 手順 9、 2の画像 2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 Motherboard Replacement: 手順 10、 2の画像 1 Nikon COOLPIX P2 Motherboard Replacement: 手順 10、 2の画像 2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 Motherboard Replacement: 手順 11、 1の画像 1
  12. Nikon COOLPIX P2 Motherboard Replacement, WiFi Card: 手順 12、 1の画像 1
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 Motherboard Replacement: 手順 13、 1の画像 1
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 Motherboard Replacement: 手順 14、 1の画像 1
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 Motherboard Replacement: 手順 15、 1の画像 1
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 Motherboard Replacement: 手順 16、 1の画像 1
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 Motherboard Replacement: 手順 17、 1の画像 1
    • Gently pull the WiFi card out of the camera.
  18. Nikon COOLPIX P2 Motherboard Replacement, Motherboard: 手順 18、 2の画像 1 Nikon COOLPIX P2 Motherboard Replacement, Motherboard: 手順 18、 2の画像 2
    • Continue removing screws from the outside of the camera body.
    • Next pull the plastic side panel off of the camera body.
    • Be extremely careful when holding the camera around the flash capacitor (circled in green), it is probably still charged, and it is very painful if you are shocked by it.
  19. Nikon COOLPIX P2 Motherboard Replacement: 手順 19、 3の画像 1 Nikon COOLPIX P2 Motherboard Replacement: 手順 19、 3の画像 2 Nikon COOLPIX P2 Motherboard Replacement: 手順 19、 3の画像 3
    • Remove the two screws connecting the strap loop to the camera body.
    • Remove the three screws from the left side of the camera body.
    • Remove the screw by the shutter button.
  20. Nikon COOLPIX P2 Motherboard Replacement: 手順 20、 2の画像 1 Nikon COOLPIX P2 Motherboard Replacement: 手順 20、 2の画像 2
    • Remove screws from plastic side cover.
    • Pull off plastic cover.
  21. Nikon COOLPIX P2 Motherboard Replacement: 手順 21、 2の画像 1 Nikon COOLPIX P2 Motherboard Replacement: 手順 21、 2の画像 2
    • Carefully remove the back housing body from the camera.
  22. Nikon COOLPIX P2 Motherboard Replacement: 手順 22、 2の画像 1 Nikon COOLPIX P2 Motherboard Replacement: 手順 22、 2の画像 2
    • Remove the five screws connecting motherboard to the camera body.
    • Carefully detach the two ribbon cables from the motherboard by releasing the black plastic catch, then pull the cables gently upwards out of the connector.
  23. Nikon COOLPIX P2 Motherboard Replacement: 手順 23、 1の画像 1
    • Carefully de-solder the four connections to the motherboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Joshua Avery
メンバー登録日: 01/23/12
31 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-28, Amido Winter 2012 Cal Poly, Team 3-28, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S3G28
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,361
