メインコンテンツにスキップ
Nike+ Sportband Motherboard Replacement
必要な工具と部品
  1. Nike+ Sportband Motherboard Replacement, External Case: 手順 1、 2の画像 1 Nike+ Sportband Motherboard Replacement, External Case: 手順 1、 2の画像 2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Motherboard Replacement: 手順 2、 2の画像 1 Nike+ Sportband Motherboard Replacement: 手順 2、 2の画像 2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Motherboard Replacement, Screen: 手順 3、 2の画像 1 Nike+ Sportband Motherboard Replacement, Screen: 手順 3、 2の画像 2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Motherboard Replacement: 手順 4、 3の画像 1 Nike+ Sportband Motherboard Replacement: 手順 4、 3の画像 2 Nike+ Sportband Motherboard Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Motherboard Replacement: 手順 5、 2の画像 1 Nike+ Sportband Motherboard Replacement: 手順 5、 2の画像 2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Motherboard Replacement: 手順 6、 3の画像 1 Nike+ Sportband Motherboard Replacement: 手順 6、 3の画像 2 Nike+ Sportband Motherboard Replacement: 手順 6、 3の画像 3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Motherboard Replacement, Motherboard: 手順 7、 1の画像 1
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Motherboard Replacement: 手順 8、 3の画像 1 Nike+ Sportband Motherboard Replacement: 手順 8、 3の画像 2 Nike+ Sportband Motherboard Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use the metal tweezers to lift the motherboard out of the device.
終わりに
作成者
5人の作成者と共同で作成されました。
Alyssa Setnar
メンバー登録日: 02/15/16
331 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 9-9, Wilson Spring 2016 IUPUI, Team 9-9, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S9G9
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 251
