メインコンテンツにスキップ
はじめに
This guide will help you replace the speaker in your Nexus S.
  1. Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Remove the rear panel from the Nexus S.
    • Remove the rear panel from the Nexus S.
  3. Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Use your thumb to slide the SIM card downwards from the SIM card slot. Remove the SIM card.
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Remove the six Phillips screws securing the rear inner frame to the inner case.
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Insert the plastic opening tool to the right of the power button. Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Lift and remove the rear inner frame from the Nexus S.
    • Lift and remove the rear inner frame from the Nexus S.
  11. Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  12. Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard. Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard. Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  13. Lift and remove the SIM Card board out of the Nexus S.
    • Lift and remove the SIM Card board out of the Nexus S.
  14. Disconnect the following cables from their respective sockets on the motherboard:
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
  15. Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards. Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage. Repeat the procedure for the digitizer and rear camera/SIM board connectors.
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  16. Remove the three Phillips screws securing the motherboard to the front display assembly.
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
  17. Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess. Lift and remove the motherboard.
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
  18. Speaker remains.
    • Speaker remains.
    • Be careful, the earpiece part is united with the speaker, you could cut the flex.
終わりに
7 の人々がこのガイドを完成させました。
Walter Galan
665,190 ポイント
1,203のガイドは作成済み
3 件のコメント
Where can I buy the speaker?
Fergal Daly - 返信
Hi, I bought a replacement for my speaker(it's dead) but, the replacement did not come with an earpiece. Can I take the earpiece from my old one and attach it to the new one. I have some soldering experience.
makenova - 返信
hey makenova,
I have the same problem. Did the soldering worked for you ?
Geert Meeusen -
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 6,591
