メインコンテンツにスキップ
Nexus S SIM Card Board Replacement
必要な工具と部品
  1. Nexus S SIM Card Board Replacement, Rear Panel: 手順 1、 1の画像 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S SIM Card Board Replacement: 手順 2、 1の画像 1
    • Remove the rear panel from the Nexus S.
  3. Nexus S SIM Card Board Replacement, Battery: 手順 3、 1の画像 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S SIM Card Board Replacement, SIM Card: 手順 4、 2の画像 1 Nexus S SIM Card Board Replacement, SIM Card: 手順 4、 2の画像 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S SIM Card Board Replacement, Rear Inner Frame: 手順 5、 1の画像 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S SIM Card Board Replacement: 手順 6、 1の画像 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S SIM Card Board Replacement: 手順 7、 2の画像 1 Nexus S SIM Card Board Replacement: 手順 7、 2の画像 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S SIM Card Board Replacement: 手順 8、 2の画像 1 Nexus S SIM Card Board Replacement: 手順 8、 2の画像 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S SIM Card Board Replacement: 手順 9、 1の画像 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S SIM Card Board Replacement: 手順 10、 1の画像 1
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S SIM Card Board Replacement, SIM Card Board: 手順 11、 1の画像 1
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  12. Nexus S SIM Card Board Replacement: 手順 12、 3の画像 1 Nexus S SIM Card Board Replacement: 手順 12、 3の画像 2 Nexus S SIM Card Board Replacement: 手順 12、 3の画像 3
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  13. Nexus S SIM Card Board Replacement: 手順 13、 1の画像 1
    • Lift and remove the SIM Card board out of the Nexus S.
  14. Nexus S SIM Card Board Replacement, SIM Card Board: 手順 14、 1の画像 1
    • SIM Card board remains.
終わりに
14 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Walter Galan
694,676 ポイント
1,203のガイドは作成済み
4 件のコメント
Where can I buy this part ? (Nexus S SIM Card Board ) ?
Andre Venancio - 返信
고액토토먹튀검증 완료 . 고액토토 환전 책임지고 먹튀검증 해드립니다. 소액부터 고액까지 안전이 제일우선 먹튀타임즈에서 함께하세요
timesjs01 - 返信
I simply want to mention I am very new to blogging and seriously savored this web page. Likely I’m going to bookmark your blog post . You amazingly come with fantastic writings. Appreciate it for revealing your blog. 먹튀검증업체
먹튀타임즈에서 먹튀검증업체를 여러분께 추천드립니다
모두 직접 연락이 가능한 안전한 먹튀검증업체입니다.
timesjs01 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 8,720
