メインコンテンツにスキップ
Nexus S Front Panel Assembly Replacement
必要な工具と部品
  1. Nexus S Front Panel Assembly Replacement, Rear Panel: 手順 1、 1の画像 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Front Panel Assembly Replacement: 手順 2、 1の画像 1
    • Remove the rear panel from the Nexus S.
  3. Nexus S Front Panel Assembly Replacement, Battery: 手順 3、 1の画像 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Front Panel Assembly Replacement, SIM Card: 手順 4、 2の画像 1 Nexus S Front Panel Assembly Replacement, SIM Card: 手順 4、 2の画像 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Front Panel Assembly Replacement, Rear Inner Frame: 手順 5、 1の画像 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Front Panel Assembly Replacement: 手順 6、 1の画像 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Front Panel Assembly Replacement: 手順 7、 2の画像 1 Nexus S Front Panel Assembly Replacement: 手順 7、 2の画像 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Front Panel Assembly Replacement: 手順 8、 2の画像 1 Nexus S Front Panel Assembly Replacement: 手順 8、 2の画像 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Front Panel Assembly Replacement: 手順 9、 1の画像 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Front Panel Assembly Replacement: 手順 10、 1の画像 1
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Front Panel Assembly Replacement, Motherboard: 手順 11、 1の画像 1
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
  12. Nexus S Front Panel Assembly Replacement: 手順 12、 3の画像 1 Nexus S Front Panel Assembly Replacement: 手順 12、 3の画像 2 Nexus S Front Panel Assembly Replacement: 手順 12、 3の画像 3
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  13. Nexus S Front Panel Assembly Replacement: 手順 13、 1の画像 1
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
  14. Nexus S Front Panel Assembly Replacement: 手順 14、 2の画像 1 Nexus S Front Panel Assembly Replacement: 手順 14、 2の画像 2
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
  15. Nexus S Front Panel Assembly Replacement, Front Panel Assembly: 手順 15、 1の画像 1
    • Front panel assembly remains.
終わりに
17 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Walter Galan
696,107 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 14,398
