はじめに
Replace the vibrator on your Nexus 9.
必要なもの
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Disconnect the two ZIF connectors attached to the daughterboards.
Gently pull on the ribbon cable to remove it.
もう少しです!
終わりに
