はじめに
Replace a faulty or broken USB daughterboard on your Nexus 9.
必要な工具と部品
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Disconnect the two ZIF connectors attached to the daughterboards.
Gently pull on the ribbon cable to remove it.
Remove the single 3mm T5 Torx screw.
Use a spudger to disconnect the display ribbon cable ZIF connector.
Gently lift the USB daughterboard up from the device.
3 の人々がこのガイドを完成させました。
