メインコンテンツにスキップ
Nexus 9 Antenna Board Replacement
必要な工具と部品
  1. Nexus 9 Antenna Board Replacement, Rear Case: 手順 1、 3の画像 1 Nexus 9 Antenna Board Replacement, Rear Case: 手順 1、 3の画像 2 Nexus 9 Antenna Board Replacement, Rear Case: 手順 1、 3の画像 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Antenna Board Replacement, Antenna Board: 手順 2、 2の画像 1 Nexus 9 Antenna Board Replacement, Antenna Board: 手順 2、 2の画像 2
    • This step is not necessary if you have already removed the battery.
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Antenna Board Replacement: 手順 3、 1の画像 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  4. Nexus 9 Antenna Board Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
90,045 ポイント
89のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 1,401
