メインコンテンツにスキップ
Nexus 7 Front Facing Camera Replacement
必要な工具と部品
  1. Nexus 7 Front Facing Camera Replacement, Rear Panel: 手順 1、 1の画像 1
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
  2. Nexus 7 Front Facing Camera Replacement: 手順 2、 2の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 2、 2の画像 2
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
  3. Nexus 7 Front Facing Camera Replacement: 手順 3、 3の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 3、 3の画像 2 Nexus 7 Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Nexus 7 Front Facing Camera Replacement: 手順 4、 3の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 4、 3の画像 2 Nexus 7 Front Facing Camera Replacement: 手順 4、 3の画像 3
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Nexus 7 Front Facing Camera Replacement: 手順 5、 2の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 5、 2の画像 2
    • Gently lift and remove the rear panel up off the front panel assembly.
  6. Nexus 7 Front Facing Camera Replacement, Battery Cable: 手順 6、 2の画像 1 Nexus 7 Front Facing Camera Replacement, Battery Cable: 手順 6、 2の画像 2
    • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
  7. Nexus 7 Front Facing Camera Replacement, Speaker Cable: 手順 7、 1の画像 1
    • Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Do not try to remove the copper shielding, as it is still attached underneath the battery.
    • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
  8. Nexus 7 Front Facing Camera Replacement: 手順 8、 1の画像 1
    • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
  9. Nexus 7 Front Facing Camera Replacement, Power & Volume ZIF Connector: 手順 9、 1の画像 1
    • Peel back the label covering the power and volume button ZIF connector.
  10. Nexus 7 Front Facing Camera Replacement: 手順 10、 2の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 10、 2の画像 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the power and volume button ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the power and volume button ribbon cable straight out of its socket.
  11. Nexus 7 Front Facing Camera Replacement, Motherboard Assembly: 手順 11、 2の画像 1 Nexus 7 Front Facing Camera Replacement, Motherboard Assembly: 手順 11、 2の画像 2
    • Carefully peel back the adhesive tape covering the I/O board ribbon cable socket on the motherboard.
  12. Nexus 7 Front Facing Camera Replacement: 手順 12、 2の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 12、 2の画像 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the I/O data ribbon cable ZIF socket.
    • Use the tip of a spudger to pull the I/O data ribbon cable straight out of its socket.
  13. Nexus 7 Front Facing Camera Replacement: 手順 13、 1の画像 1
    • Peel back the adhesive tape covering the display and digitizer cable sockets.
    • It is not necessary to completely remove the adhesive, but it is helpful to fold it back on itself to get it out of the way.
  14. Nexus 7 Front Facing Camera Replacement: 手順 14、 1の画像 1
    • Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
  15. Nexus 7 Front Facing Camera Replacement: 手順 15、 3の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 15、 3の画像 2 Nexus 7 Front Facing Camera Replacement: 手順 15、 3の画像 3
    • Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets.
    • Make sure you are flipping up the retaining flaps, not the sockets themselves.
    • Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
  16. Nexus 7 Front Facing Camera Replacement: 手順 16、 2の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 16、 2の画像 2
    • Use the tip of a spudger to remove the warranty seal stickers.
  17. Nexus 7 Front Facing Camera Replacement: 手順 17、 1の画像 1
    • Remove the following screws securing the motherboard to the metal frame:
    • Six 3.25 mm silver Phillips screws
    • One 2.23 mm black Phillips screw
  18. Nexus 7 Front Facing Camera Replacement: 手順 18、 2の画像 1 Nexus 7 Front Facing Camera Replacement: 手順 18、 2の画像 2
    • Carefully lift the motherboard assembly out of the Nexus 7, minding any cables that may get caught.
  19. Nexus 7 Front Facing Camera Replacement, Front Facing Camera: 手順 19、 1の画像 1
    • Use the flat end of a spudger to pry the front-facing camera straight up off its socket on the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Walter Galan
696,445 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 10,118
