メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will go over the process of how to repair a faulty or malfunctioning front facing camera on the Nexus 7. The camera is modular, so a simple replacement will be the easiest method of repair.
パーツ
パーツは指定されていません。
  1. In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
  2. Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly. Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
  3. Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7. Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7. Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Pry up the rear panel along the left edge using the method described in previous steps. Pry up the rear panel along the left edge using the method described in previous steps. Pry up the rear panel along the left edge using the method described in previous steps.
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Gently lift and remove the rear panel up off the front panel assembly. Gently lift and remove the rear panel up off the front panel assembly.
    • Gently lift and remove the rear panel up off the front panel assembly.
  6. Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard. Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
    • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
  7. Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Do not try to remove the copper shielding, as it is still attached underneath the battery.
    • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
  8. Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
    • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
  9. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  10. Peel back the label covering the power and volume button ZIF connector.
    • Peel back the label covering the power and volume button ZIF connector.
  11. Use the tip of a spudger to carefully flip up the retaining flap on the power and volume button ribbon cable ZIF socket. Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to carefully flip up the retaining flap on the power and volume button ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the power and volume button ribbon cable straight out of its socket.
  12. Carefully peel back the adhesive tape covering the I/O board ribbon cable socket on the motherboard. Carefully peel back the adhesive tape covering the I/O board ribbon cable socket on the motherboard.
    • Carefully peel back the adhesive tape covering the I/O board ribbon cable socket on the motherboard.
  13. Use the tip of a spudger to carefully flip up the retaining flap on the I/O data ribbon cable ZIF socket. Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to carefully flip up the retaining flap on the I/O data ribbon cable ZIF socket.
    • Use the tip of a spudger to pull the I/O data ribbon cable straight out of its socket.
  14. Peel back the adhesive tape covering the display and digitizer cable sockets.
    • Peel back the adhesive tape covering the display and digitizer cable sockets.
    • It is not necessary to completely remove the adhesive, but it is helpful to fold it back on itself to get it out of the way.
  15. Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
    • Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
  16. Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets. Make sure you are flipping up the retaining flaps, not the sockets themselves. Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
    • Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets.
    • Make sure you are flipping up the retaining flaps, not the sockets themselves.
    • Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
  17. Use the tip of a spudger to remove the warranty seal stickers. Use the tip of a spudger to remove the warranty seal stickers.
    • Use the tip of a spudger to remove the warranty seal stickers.
  18. Remove the following screws securing the motherboard to the metal frame:
    • Remove the following screws securing the motherboard to the metal frame:
    • Six 3.25 mm silver Phillips screws
    • One 2.23 mm black Phillips screw
  19. Carefully lift the motherboard assembly out of the Nexus 7, minding any cables that may get caught. Carefully lift the motherboard assembly out of the Nexus 7, minding any cables that may get caught.
    • Carefully lift the motherboard assembly out of the Nexus 7, minding any cables that may get caught.
  20. Use the flat end of a spudger to pry the front-facing camera straight off of its socket on the motherboard.
    • Use the flat end of a spudger to pry the front-facing camera straight off of its socket on the motherboard.
  21. Carefully pull the upper microphone straight up off its socket. In a similar fashion, remove the rubber lower microphone gasket from the motherboard.
    • Carefully pull the upper microphone straight up off its socket.
    • In a similar fashion, remove the rubber lower microphone gasket from the motherboard.
  22. Motherboard remains.
    • Motherboard remains.
  23. Flip the motherboard over to reveal the ZIF connectors for the two cameras. The front facing camera will be the one on the left side. Start by prying the locking bar of the ZIF connector up with a spudger. The front facing camera will be the one on the left side. Start by prying the locking bar of the ZIF connector up with a spudger.
    • Flip the motherboard over to reveal the ZIF connectors for the two cameras.
    • The front facing camera will be the one on the left side. Start by prying the locking bar of the ZIF connector up with a spudger.
  24. Place the pointy end of the spudger underneath the cable ribbon to pull it from the connector. Pry the camera off of the motherboard from the cable side and remove it from the motherboard.
    • Place the pointy end of the spudger underneath the cable ribbon to pull it from the connector.
    • Pry the camera off of the motherboard from the cable side and remove it from the motherboard.
    • You will likely damage the ribbon cable of the old camera when prying due to the strong adhesive used, but as long as you've got a replacement it shouldn't be a problem. You also may want to put a small drop of adhesive beneath the camera to affix it to the motherboard after installing it.
終わりに
Austin Blakely
メンバー登録日: 2019年03月11日
4,497 ポイント
25のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
124 メンバー
11,578のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 102
