メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nexus 7 2nd Generation Back Cover Replacement
必要な工具と部品
  1. Nexus 7 2nd Generation Back Cover Replacement, Back Cover: 手順 1、 2の画像 1 Nexus 7 2nd Generation Back Cover Replacement, Back Cover: 手順 1、 2の画像 2
    • Power down your device.
    • Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
    • Do not pry near the USB port at the base of the device as you may crack the rear panel.
  2. Nexus 7 2nd Generation Back Cover Replacement: 手順 2、 1の画像 1
    • Work fingers around the seam between device and back cover. Use your plastic opening tool and fingers to separate each side until device and back cover are completely apart.
    • Be careful around the corners. The body of the device can be fragile.
終わりに
16 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Heather
メンバー登録日: 01/22/15
1,428 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-16, Maness Winter 2015 Cal Poly, Team 20-16, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S20G16
4 メンバー
26のガイドは作成済み
4件のガイドコメント
Step left out. ifixit.com video on Youtube show use of craft knife as first step to get into very tight case fitting, then the use of plastic pry tool to go around releasing the backcover.
nodakman84 - 返信
I didnt read the comment about it being tight and using a knife, until I had damaged the prying tools :-(
Bill Walker - 返信
How do u take off the cover do u have to have that tool
Sharon Catalli - 返信
I had very little problem prying of the back of my nexus 7 2012. Once you get the first corner done, the rest comes pretty easy.
I ended up using an old hotel keycard as a spudger and it worked fine.
I needed access to the cables that connect the touchscreen to the motherboard so that my touch screen would respond.
Worked like a charm!
Mister Muscles - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 49
今までの合計 13,448
