メインコンテンツにスキップ
Nexus 7(1st Generation) Battery Replacement
必要な工具と部品
  1. Nexus 7(1st Generation) Battery Replacement, Taking the rear case off.: 手順 1、 1の画像 1
    • Use the opening tools to open the rear case.
    • Be careful when opening rear case because the rear case clips can break.
  2. Nexus 7(1st Generation) Battery Replacement, Taking battery out: 手順 2、 1の画像 1
    • Frist take the spudgler tool to move the wires from the mother board.
    • Second use the tool to pry the battery out of the top then do this at the bottom. Be careful when you do this because there is adhesive under the battery.
    • Im sorry I don't have picture of taking the battery out but the first picture in the circled part that is the motherboard.
    • When you put the new battery in you first put the battery in then you move the wires to the motherboard then but the case back on.
    • Turn the tablet on and there you go. Thank you for using my guide and if it was helpful please leave a comment or if something is not correct on my guide leave a comment and I will fix the correction in my guide.
終わりに
To reassemble your device follow step 3.
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Skyler Wright
メンバー登録日: 07/07/17
132 ポイント
1ガイドが承認済み
2件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 24
今までの合計 1,277
