メインコンテンツにスキップ
Nexus 6 Rear Facing Camera Replacement
必要な工具と部品
  1. Nexus 6 Rear Facing Camera Replacement, SIM Card: 手順 1、 1の画像 1
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
  2. Nexus 6 Rear Facing Camera Replacement, Rear Case: 手順 2、 2の画像 1 Nexus 6 Rear Facing Camera Replacement, Rear Case: 手順 2、 2の画像 2
    この手順で使用する道具:
    iOpener
    $12.99
    購入する
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpenerの使用方法 for info on how to use it.
  3. Nexus 6 Rear Facing Camera Replacement: 手順 3、 1の画像 1
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  4. Nexus 6 Rear Facing Camera Replacement: 手順 4、 3の画像 1 Nexus 6 Rear Facing Camera Replacement: 手順 4、 3の画像 2 Nexus 6 Rear Facing Camera Replacement: 手順 4、 3の画像 3
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
  5. Nexus 6 Rear Facing Camera Replacement, Rear Facing Camera: 手順 5、 2の画像 1 Nexus 6 Rear Facing Camera Replacement, Rear Facing Camera: 手順 5、 2の画像 2
    • Use the spudger to release the rear facing camera connector.
    • Use tweezers to gently remove the rear facing camera.
終わりに
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Marina Moore
メンバー登録日: 01/13/15
4,293 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 70-3, Forte Winter 2015 Cal Poly, Team 70-3, Forte Winter 2015人のメンバー
CPSU-FORTE-W15S70G3
4 メンバー
30のガイドは作成済み
3 件のコメント
Even though I followed the guide, step by step, and heeded all the advice, once reassembled I cannot get the phone to restart.
Charles Brittain - 返信
check the power and volume ribbon cable and the connector at the top left of the device, it could be loose..
hussain alshaykhnasir -
I had the same problem. But it resolved itself when I connected the charger to the phone.
Thomas Boehm -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 4,554
